Oil Pan Drain Hoses >
Oil Pan Drain Hoses
Oil Pan Drain Hoses
Old 10-14-2009 | 12:17 AM
sleek1's Avatar
Default Oil Pan Drain Hoses
Do any of you have the hoses attached to the bottom of your oil pan to drain oil? If so, what size are they and where did you get them? I was going to have them installed last time my engines were out but they were too thick to pull out by bilge drain holes. My engines are out (again) and I would like to install these hoses.
sleek1 is offline
Old 10-14-2009 | 12:18 AM
c_deezy's Avatar
CP sells them. Not sure if they are small enough to come out through the drain plug tho.
c_deezy is offline
Old 10-14-2009 | 12:45 AM
Strip Poker 388's Avatar
Rob
Overtons,ya can do a search on goggle it will show a few other.thieve been running around 14-20. I put longer hoses on mine
Picks post 15
http://www.offshoreonly.com/forums/h...-how-easy.html
Strip Poker 388 is offline
Old 10-14-2009 | 03:49 PM
sleek1's Avatar
So they aren't meant to be pulled thru the bilge drain plugs, they're meant to be connected to a drain pump?
sleek1 is offline
Old 10-14-2009 | 07:33 PM
Mentalpause's Avatar
They connect to the drain plug by chain so when you take the plug out you can pull them through the hole.
Mentalpause is offline
Old 10-14-2009 | 07:55 PM
J.B. Marshall's Avatar
JB Marshall
Sleek, this might be what your looking for http://www.cpperformance.com/detail.aspx?ID=902
J.B. Marshall is offline
Old 10-14-2009 | 08:16 PM
Check into the hoses that Merc uses on the 525's, actually I think they install them on every engine package these days, they will pull thru the standard size hull drain plugs. Bam Marine site should allow you to find the part numbers.
RaggedEdge is offline
Old 10-14-2009 | 10:55 PM
sleek1's Avatar
Thanks for the help guys, that is exactly what I'm looking for.
sleek1 is offline
Old 10-14-2009 | 11:59 PM
Rob
Talking
either or. I just suck mine out.quick connect fitting make it nice ,not a drip,mines 5 gallons at a time
rob
Old 10-15-2009 | 08:57 AM
axapowell's Avatar
Where To
Hey Rob, What quick connect fittings do you use? Do you have a picture or part number?
I have the hoses to the oil pan, y-block and quick change pump installed in my boat, but have never been able to find a GOOD quick connect for the output side of the pump.
Thanks,
Dave
axapowell is offline
