Gas Smell
Old 10-19-2009 | 01:48 PM
If it's also in the cuddy then I agree it's prolly the tank and you got gas fumes running all under the hull... Your tanks under the floor or accessible? Hopefully you don't have to cut out the floor like I just had to on a donzi
FuelinAround is offline
Old 10-19-2009 | 02:20 PM
jaybird's Avatar
As said, sounds like the fuel tank has leaks. I had to replace the tank in my 1987 Formula. For some reason the tank did not have the ground wire on it which is supposed to help with corrosion. Plus the boat is 20+ years old - not uncommon for the tank to fail.
I have had 2 gas tanks fail, both with no visible gas anywhere, but stunk up the cabin more than anytihing.
If you smell gas you have a leak. DON'T USE THE BOAT UNTIL YOU FIGURE IT OUT! As I said unfortunately it probably is the tank which is not a fun or cheap job. You can have the tank pressure tested to figure out whether it is leaking for certain. Good luck!
jaybird is offline
Old 10-19-2009 | 03:14 PM
I have a excess panel Im going to pull and look to this weekend. If it is the tank were do I order new one from ?
BiLLyLaurianO is offline
Old 10-19-2009 | 04:08 PM
jaybird's Avatar
You probably won't be able to see much from the access panel. I forget where I ordered mine from, but there are many companies who make them. You measure your old tank and they custom build it. It's a beetoch to get them out - it will be foamed in there and will need to be cut out. I had my marina do the work -too much for me. On one boat I stripped as much of the interior out as I could to help and save $$. Your local boatyards / marinas probably have a shop they use to build tanks. Do some shopping and searches here, plus ask in the general forum. I got quotes from $800 to $1800 just for the tank part alone for 150gal.
jaybird is offline
Old 10-19-2009 | 06:37 PM
Has the boat been run in heavy seas? If so did you notice the fuel smell after or during that time? It's happened to me. You may have a cracked fuel tank, cracked at the seams at the weld. It's a pain in the azz, but an easy fix. It happened in my race boat a 382.
scandelous is offline
Old 10-20-2009 | 07:57 AM
mrv8outboard's Avatar
coolrunning racing
Replace the tank! Also when the tank is out check the stringers. The port side is the one that usually lets go from the bottom. This is also a good time to replace you fuel fill,vent and pick up hoses. Replace the grounding leads also.
mrv8outboard is offline
Old 10-20-2009 | 09:25 AM
Check the gasket on the fuel sender they leak and it not hard to replace.
formula 382 sr-1 is offline
Old 10-20-2009 | 11:12 AM
I looked everywhere but tank yesterday. And didnt see nothing wet or stained.. Plus smell seems stronger since my drive way is on slant.. I also notice there was only one blower.. Is that right ?
Old 11-07-2009 | 08:50 PM
don
Sounds like the tank is shot. If all seals look good and you can try to tape the vent then put a little pressure into the tank you will see the leak is in the tank. Spray soapy water at any connections in the gas line.
don is offline
Old 11-09-2009 | 11:51 AM
jaybird's Avatar
Have the tank pressure tested.
jaybird is offline
