Fast Formula 98.4 >
Fast Formula 98.4
Fast Formula 98.4
Old 04-28-2010 | 10:51 PM
PAST DUE's Avatar
Default Fast Formula 98.4
http://www.youtube.com/watch?v=OuG6A6T5zJs
PAST DUE is offline
Old 04-28-2010 | 11:29 PM
Wise A**'s Avatar
Nice, how do you keep it so smooth? Mine gets really squirily around 95. The fastest mine has ben is 101. Similar setup, 29p props, 1.34 imcos with short bottoms, 5800 rpms.
[SIGPIC][/SIGPIC]
Wise A** is offline
Old 04-29-2010 | 11:09 AM
PAST DUE's Avatar
This setup is with 1.36 gears with 32p stock bravo props turning 5300 rpm. 460 block 715 hp and 800 ibs of torque Tyler Crockett built tough
PAST DUE is offline
Old 04-29-2010 | 12:33 PM
Has the bottom been blue printed?
4mulafastech is offline
Old 04-29-2010 | 12:46 PM
David,
Great number, what kind of upgrades to the motors? Good luck with the drives.
Brad
Brad is offline
Old 04-29-2010 | 01:37 PM
PhantomChaos's Avatar
Holy cow that is fast for a 312! Congrats guys!
PhantomChaos is offline
Old 04-29-2010 | 05:46 PM
PAST DUE's Avatar
Wise A, i have a few secrets for the good hookup will try to get you some pics in a P.M. 4mulafastech, have not touched the bottom be would like to know if you have any ideas to free it up a little the boat still runs wet. The new props from BBLADES are going to have some more cup added to them to get the bow lifted some i hope. Brad, the uppers were built by Dick Tryce of Dicks Performance Marine with all his upgrades (Mr Gadgets on here) read a few post i think you will find that the drives will be ok i built the lowers myself with all XR parts and with a little sense i think they will be ok also.
PAST DUE is offline
Old 04-30-2010 | 08:32 AM
I don't have experience with Fastech hull blueprinting, but I can see on my 292 there is room for improvement. The trailing edges of the steps and where the bottom meets the notched transom have a large radius. This makes it easier to pop the hull from the mold. That large radius prevents the water from breaking free as easy as it would with a sharper radius. I would think at the speeds you are running making improvements to those edges can make a difference.
I plan to make serious upgrades sometime in the future with my 292, so it is interesting seeing a similar hull (your 312) running so nice. I know they are different animals (small blocks Vs big blocks), but both are similar in length and Fastech hulls. Mine weighs around 7500 lbs. How about your 312?
From the numbers posted your slip is around 17%. I think there is definitely room for improvement there. I have read good things about Brett at BBlades and his ability to tweak Bravo props. I'm sure he has some ideas on how to free up the hull with some prop work and improve those slip numbers.
If you don't mind, PM those hookup secrets to me as well. Again, very impressive 312. I'm sure it will be a consistent 100mph+ runner after fully dialed in.
Old 04-30-2010 | 10:03 AM
Wise A**'s Avatar
Past Due, would appreciate the p.m. I'm running 502s stroked to 540ci, aluminum heads, whipples cranked to the max pully size, around 7 psi boost. Plenty of power, but the boat is extremely hard to drive from low 90s up. Think i could go faster if it wasnt so spooky. My props are spinning out, thought about trying in, wich way are yours?
[SIGPIC][/SIGPIC]
Wise A** is offline
Old 04-30-2010 | 06:25 PM
PAST DUE's Avatar
I am turning my props in it lifts the back of the boat better and mine got a little more stable when i did this i will have those pm to you guys in a little while. I think we are going to end up sanding the bottom of the boat with 400 wet sand paper is supposed to show good results
PAST DUE is offline
