382 Drive Alignment? >
Old 07-12-2010 | 12:07 PM
BONDO10's Avatar
Default 382 Drive Alignment?
I know this has been posted many times,but I'm looking for specifics. Where should my XR's be set on a 2004 382. Toed in, out, or straight? Right now they are 1/2 inch in,and it just seems a little much. Any help would be appreciated.
BONDO10 is offline
Old 07-14-2010 | 03:22 AM
drives in or out i have always set mine at o, not in or out you will hear toe in or out from others and I will not disagree but, less resistace means more speed and I have not seen any nevgative handling results on my Formula's v-hulls and step hulls with setting the drives at 0 % in or out.
Thanks,
Jeff
Jeff H is offline
Old 07-14-2010 | 06:42 AM
BONDO10's Avatar
Jeff
Thanks for the input. I will set them up at 0 this weekend and give them a try.
BONDO10 is offline
Old 07-16-2010 | 12:57 PM
I once read somewhere (Teague tips i think) 1/8 inch in if you turn your props in and 1/8 inch out if you turn your props out. The theory behind this is that the spinning torque of the propellers will then actually make the drives at zero at speed.
Rawpower is offline
