PC 34 A/C Question
The one pic shows the original version prior to the complete overhaul, pump is on the side of the stringer. Since I added new thru hull motor pickups and large strainers, I relocated the ac strainer and pump to the forward bulkhead and under the folding step.
Hope this helps a little.
Correct-a-mundo......it actually picks up the galley sink drain, the floor drain in the head for the shower as well as the head sink drain, they all plumb into the main drain that comes into the bilge under the genset. The sump box has a little strainer, float and pump.
