A/C ???s
we go in the cabin quite often to make drinks so access there would be important. i am thinking of a portable unit from Home Depot and using an inverter and placing the self contained unit exactly where yours is up on the side of the bed. guess i would have to create an exhaust vent somewhere?
I actually ended up grabbing a window unit and making a shroud that forces the air down through a deck hatch. That way the cabin door is still useable.
As a side note, some of those portable units don't cool worth a damn, and you need to have an easy place to vent the hot air.
Be carefull with an inverter, with a typicall AC unit on a hot day you will kill even the biggest batteries in under an hour.
I was going to do an install like T500's did, but the window unit works so well for $99 i decided against it. My next boat will have AC built in
I don't know of a portable unit that could sit INSIDE the cabin like your asking. I also wouldn't expect an inverter powering a AC with 2 group 27 batteries to run the thing for more than 2-4 hours before starting the motors becomes a real concern. and remember, cooling air creates heat and moisture.....both of those have got to go somewhere.
If you only plan to run an hour or so on bat you should be fine. Here's another thread on inverters and AC...
http://www.offshoreonly.com/forums/g...-inverter.html
