My 292 in a poker run >
Old 09-14-2010 | 09:30 PM
Expensive Date's Avatar
Originally Posted by 08 fastech 292
Was that a DIY job or did you have someone install them?
I did it myself hard to say how long it took because while I had it apart I did plugs impellers.fuel filters and thermostats.But if you have everything I would probably say a day.It is bolt on but there are some changes that have to be made.I had to redrill a few holes in the ECM bracket and you can not use the corsa mid pipes.I just went 4'hose from the risers to the transom tips.There are a few other little things that I will go over with you if you decided to do it.
A lot depends on your mechanical ability its not hard but I have played with engines all my life.
Also keep in mind your boat is newer this technically void your warranty.I had a riser start leaking at the end of last season so thats the main reason I did this I never expected it to make the boat come out of the water faster like this.
Expensive Date is offline
Old 09-14-2010 | 09:31 PM
Originally Posted by Expensive Date
They have corsa pipes from the mercury cast iron manifolds and risers.I eliminated them and just ran 4" exhaust hose from the riser to the tips.I blocked off the prop exhaust with plugs I got from cp performance and removed one baffle from each tip.
Thanks, makes sense.
Digital Jams is offline
