Put the bird in a nest >
Old 10-02-2012 | 10:54 AM
  #161
PhantomChaos's Avatar
Originally Posted by axapowell
Got a little tick, tick, tick myself to explore over the winter. Fix it, you boat year round anyways, right?
Dave
Here's what was causing the tick tick.
Attached Thumbnails Put the bird in a nest-gear-1.jpeg   Put the bird in a nest-gear-2.jpeg
PhantomChaos is offline
Old 10-02-2012 | 11:45 AM
  #162
Audiofn's Avatar
Charter Member #232
It seems to be fine.....thye problem was the application of the product by Formula, not Plexus.
What do ya have an hour on that thing since you fixed it?
I thought the whole idea behind cali was year around boating.....
Flip those gears over and you can probably get another 3 years out of them.
Put your best foot forward!
Audiofn is offline
Old 10-02-2012 | 12:06 PM
  #163
LOL.....10 hours! It's all fixed now.....just the headliner BS to deal with now.
Old 10-03-2012 | 11:16 AM
  #164
C_Spray's Avatar
Diamond Member #001
...now we're on to ripping out the headliner and redoing that. While we're at it, we're redoing the area where the TV was and finishing that. Endless......it truely is!
Nort - You're just catching up to some of us. I re-did the TV in 2004, and the headliner in 2011.
Of course, now I have some hull/deck touchup to do....
C_Spray is offline
Old 12-07-2012 | 10:51 AM
  #165
Finally got the material from Formula. Panels are all out and ready to tear into. A couple of comments:
  • The black foam backing falls apart if you touch it. The third pic shows where I rubbed lightly with my thumb.
  • The round wood blocks are where the recessed lights go. These are stapled on (a problem I had years ago with the headliner falling down). We are redoing all of these with 5052 and screws.
  • I was considering replacing the "yellow" foam cushion areas but the foam seems fine (for now) and doesn't fall apart.
  • We are going to add audio and HD video cables along the roof from the new Kenwood DDX719 head unit to the new flatscreen going in.
  • Replacing all the bulbs in the cabin with LEDs LINK
Easy stuff!
Attached Thumbnails Put the bird in a nest-img_6026.jpg   Put the bird in a nest-img_6027.jpg   Put the bird in a nest-img_6028.jpg
Put the bird in a nest-img_6029.jpg   Put the bird in a nest-img_6030.jpg   Put the bird in a nest-img_6031.jpg
Put the bird in a nest-img_6032.jpg   Put the bird in a nest-img_6033.jpg   Put the bird in a nest-img_6034.jpg
Old 12-07-2012 | 10:53 AM
  #166
More...........enjoy!
Attached Thumbnails Put the bird in a nest-img_6036.jpg   Put the bird in a nest-img_6037.jpg   Put the bird in a nest-img_6038.jpg
Put the bird in a nest-img_6039.jpg   Put the bird in a nest-img_6040.jpg   Put the bird in a nest-img_6041.jpg
Put the bird in a nest-img_6042.jpg   Put the bird in a nest-img_6043.jpg   Put the bird in a nest-img_6044.jpg
Old 12-07-2012 | 12:07 PM
  #167
C_Spray's Avatar
Diamond Member #001
Nort, do yourself a favor and cut down any edge of the outer panels that slides behind a wall or bulkhead to no more than 2" of overhang. This is particularly true over/behind the TV panel. This will make re-installation far, FAR easier.
Also, get two of those thin plastic sheets that are used for kitchen cutting boards, and put one above and below the ceiling panels as you slide them back in. This will prevent bunching up the foam rubber into a big log, and will protect the new vinyl.
Another thing that helps is to remove the mirror panel at the front of the v-berth. Lift up the front cushion and you will find two aluminum brackets screwed into the floor with two screws each. Remove the four screws and pull backwards on the bottom of the panel. It will pivot out until the pin at the top disengages, and then you can remove it completely.
C_Spray is offline
Old 12-07-2012 | 12:12 PM
  #168
Thanks Chuck! I passed it on.
Old 12-09-2012 | 06:22 PM
  #169
Audiofn's Avatar
Charter Member #232
Then go out and buy an OL. You will save money!
Audiofn is offline
Old 12-09-2012 | 09:30 PM
  #170
Expensive Date's Avatar
Just gut it and do bulkheads like the raceboats, it will solve all of the problems.
Expensive Date is offline
