? on the center stringer >
Old 10-24-2010 | 04:31 PM
Default ? on the center stringer
Twin engine 336 or other twin,my center stringer sounds hollow like formula just boxed it and didnt add any center supports..
thanx in advance..
FIXX is offline
Old 10-24-2010 | 05:31 PM
spazboz's Avatar
When we gutted the 357 and rebuilt it, we found that the stringers were 3 layers of 3/4". Only where the offshore mounts bolted to it was it all 3 layers. Everywhere else it was the outside two boards and no center board. When we redid it, we made it all 3 layers all the way. On that boat, it was hollow in the middle.
spazboz is offline
Old 10-24-2010 | 08:35 PM
Default Fixx
Thanx for the reply,, mine is solid but i just sounds hollow when you knock on it and was wondering how thick it was..
FIXX is offline
Old 10-25-2010 | 07:43 PM
offthefront's Avatar
Mike ...take a look at my thread on the 311 stringer repairs ... the center stringer had solid wood thruout ...problem was the bottom of the stringer was not sealed ...so water that was in the V under the stringer could soak up into the plywood ....m
http://www.offshoreonly.com/forums/f...6-project.html
Attached Thumbnails ? on the center stringer-rot.jpg   ? on the center stringer-rot2.jpg   ? on the center stringer-rot3.jpg
offthefront is offline
Old 10-25-2010 | 10:42 PM
Default Fixx
Thanx mike,i took the center motor mounts off and looked in their with the boar scope..looks solid
I would have thought that formula would have done what you did by filling the void between the outter sheets of wood..i guess they thought leaving it hollow would be strong enough..i may open it up and fill the center to my standards..
i was going to install the offshore mounts that came with the sc engines..i saw that you did not install them,courous why you ddidn't?
FIXX is offline
Old 10-26-2010 | 10:25 AM
spazboz's Avatar
That's the wider style stringer in the 311's. The 357 had the narrower center stringer. This isn't the best picture, but its all I have left. You can see the narrower style in the right corner of the picture. Not sure which one you had.
spazboz is offline
