IMO......Formula may have a safety isssue with the hull/deck bonding. >
Old 02-12-2011, 11:26 PM
  #141
Originally Posted by Back4More
So if you look in the side storage compartments what is it you'll be looking for? Gaps? Plexis squeezed out? Or do you have to pull the rub rail off?
Does this come down to a surface prep issue on some boats?
Inside the gunnels, you will see a piece like the picture that is posted earlier, with the nut that is on the through bolt going all the way through the deck.hull and into the plate. You should not be able to see anything else, as it covers the seem between the deck/hull
Zone 5 is offline
Old 02-12-2011, 11:32 PM
  #142
Originally Posted by fossil fuel
This is not a end of the world fix and no paint work is required if you are careful.
What are you doing to fix it? Are you just replacing bolts? or are you re glueing it with something?
Zone 5 is offline
Old 02-13-2011, 12:00 AM
  #143
Remove all the bolts, remove all the plexus, Re apply plexus in a liberal amount, reinstall squeeze bolts and resqueeze to plexus recommended amount. When finished we had plex squeezing out of the seam inside and out. I would estimate we had 3 times the material in the seam than we took out. See the first few pages of this thread on the plex. Thanks, Dave
fossil fuel is offline
Old 02-13-2011, 06:02 AM
  #144
Charter Member #232
Audiofn's Avatar
Dave, Back a few pages you said that there was to be a .05" layer of plexus left after you bolt the hull halfs. How did you accomplish this? Do you know if they used feeler guages or some type of spacer? I would assume that if you just tightened the bolts that you would squeeze most of it out?
Jon
Put your best foot forward!
Audiofn is offline
Old 02-13-2011, 06:16 AM
  #145
Originally Posted by Audiofn
Does anyone have any objection if I go through and clean out any of the banter that does not specifically relate to this topic? I think that with this looking like it may be more serious then we thought it is important that we keep it 100% on topic. Mostly I am thinking get rid of all the financing stuff?
Jon
Sorry I don't know know what the word banter means, but I believe I get the general idea here.
Actually I did not intend to answer the financing part any more in this thread, and genereally speaking I am all for keep threads "clean" and stick to the subject, but since Expensive Date has made the same comment in other threads too, I wanted to check if he can substantiate, what I believe is his point of view, as opposed to fact.
I don't object to deleting all the financing stuff including my comments, as long as Expensive Date's original comment about Formula not holding their value is deleted too. If that comment is not deleted, I will object.
Phazar454Mag is offline
Old 02-13-2011, 11:49 AM
  #146
There seem to be many different Plexus adhesives, anybody that knows the specific product that is used for the deck bonding ?
Old 02-13-2011, 11:58 AM
  #147
Shouldn't you somehow bind the deck and hull together to allow for a tight seal? Not sure how you can do this.
VtSteve is offline
Old 02-13-2011, 03:07 PM
  #148
What product did you use for the repair job ?
Maybe it is on this list: http://www.itwplexus.com/UserFiles/F...ectorGuide.pdf
Old 02-13-2011, 05:01 PM
  #149
I will look at the tubes. It is the same product number that Formula uses. Before we applied it to the seam we ran some tests on old fiberglass scraps we had laying around the shop. We tested it on dirty panels with no cleaning other that wipe off the dust with a rag, We sanded a panel and one we just scraped. The next day we broke them apart. All of the panels ripped to the structural mat ! It seems the plex penetrates the gel coat as advertised. It did not matter dirty or clean. I think this is why you need to leave 1/8" in the seam so it has the chemistry to work.
Old 02-13-2011, 05:21 PM
  #150
Expensive Date's Avatar
So am I to understand that in your opinion the failure was caused by lack of adhesive?
Expensive Date is offline
