353 power inverter? >
353 power inverter?
353 power inverter?
Old 03-20-2011 | 05:25 PM
Default 353 power inverter?
I have an 01 353 with out a gen but with shorepower. I was wondering if they have a built in power inverter that would run off the batteries so i could plug in regular house items like a blender and stuff?
soonenough is offline
Old 03-20-2011 | 06:40 PM
My 353 doesn't, I don't think any of them do, unless it was a special order, but you can buy one and run it off your batteries, that's what I'm doing for short periods of time.
314joey is offline
Old 03-20-2011 | 07:37 PM
C_Spray's Avatar
Diamond Member #001
Figure out what your total heaviest load might be and then select one from there. You can probably get by with a unit small enough to tuck in near the electrical panel, where you can hook it up to the heavy 12v power cables that feed from the engine compartment.
C_Spray is offline
Old 03-21-2011 | 02:09 PM
offthefront's Avatar
mount the inverter as close to the Batteries as possible and run AC cord up to cabin ....more efficent .... I mounted a 1500 watt Harbor Freight under the rear seat and ran Extension cords up both sides of the boat into the cabin .....m
http://www.theinverterstore.com/?gcl...FYHb4Aodi0_99w
offthefront is offline
Old 03-21-2011 | 07:30 PM
C_Spray's Avatar
Diamond Member #001
Maybe 353's are wired differently from my 382. 382's have a pair of 1/0 gauge (heavy) battery cables running from the engine compartment to the electrical distribution panel in the cabin. No voltage drop there.
Be careful about mounting ANY inverters in the engine compartment. Most are not USCG-approved for that, and some will overheat.
C_Spray is offline
Old 03-21-2011 | 07:53 PM
Correct .... I mounted mine under the rear seat ....on the front wall towards the cockpit .....m
Old 03-21-2011 | 08:59 PM
Thanks for the input guys!
