How to get silent choice on a 98 Fastech >
Old 05-09-2011 | 08:30 AM
Fountain4402's Avatar
Default How to get silent choice on a 98 Fastech
Buddy and I are trying to figure this out. IF we take off the ST baffles we will have the normal two holes for through hull exhaust. At that point put 4in tips on it or whatever size they are. So at this point we would be at a thru hull exhaust loud all the time.
What about getting silent choice on it Because it doesnt have a Y pipe for exhaust to be diverted through the prop. Is there some solenoid that controls noise a little but still lets water and exhaust out. Or could you just add a Y pipe and get a normal corsa diverter and the exhause comes out like that.
Fountain4402 is offline
Old 05-09-2011 | 09:03 AM
you will need to pull out engine/s to get y pipes in..
Attached Thumbnails How to get silent choice on a 98 Fastech-bumbers-001.jpg
boatnt is offline
Old 05-09-2011 | 09:30 AM
isnt there a diverter you can use so you dont need to do the Y pipe and just go straight out the back,
Old 05-09-2011 | 09:34 AM
Ted G's Avatar
The diverter either dumps the exhaust into the Y pipe or out the back. So you will need the Y-pipe installed and then the diverters installed. It is much cheaper to put on full time mufflers out the back unless you just have to have wide open exhaust.
www.cbpba.com
Ted G is offline
Old 05-09-2011 | 09:41 AM
you will need a Y pipe and diverters.
in the picture you can see the diverters turning down to the y pipe
boatnt is offline
