port side motor squeeling
Have you tried running the engine (under a fair amount of load) on muffs, with the engine hatch open and having someone listen to where the squeal seems to be coming from. I can't believe you can't detect, or close to, where the issue is.
I tried searching but found nothing on the forums...Does anyone know if the latham power steering system on the Formula Fastech's only uses one hydraulic steering pump? I have hydraulic pumps on both engines but only one seems to be plumbed in...I have a lot of squeeling from the port side pump and instead of replacing it, i am looking to just buy a smaller belt and skip the pulley altogether. any input is appreciated.
just looking for a quick fix for vacation until i can replace it...
In all of the applications I have seen, Formula only uses one of the pumps. Usually on the starboard side, the other pump is sometimes left on the opposite motor with a hose that connects the in and out as a loop thru. I would shorten that belt and leave it that way. There is no reason to run the spare pump.
Dave
Dave
