382's What props you runnin? >
Old 06-22-2011 | 01:09 PM
SlowPlay's Avatar
Default 382's What props you runnin?
I;m dealin with an issue right now and im curious what everyone is runnin.
what props / power is everyone runnin on the 382's and the fastech's
SlowPlay is offline
Old 06-22-2011 | 02:47 PM
J.B. Marshall's Avatar
JB Marshall
500 EFI's I run 28" Bravos, with that being said I want to move up to 30" and work with them to dial in better cruise speed.
Do a search there were a no# of prior discussions on this.
Good Luck,
JB
J.B. Marshall is offline
Old 06-22-2011 | 03:21 PM
SlowPlay's Avatar
jb.... 28 4 blades? how my hp are your efi's? what kidn of speeds are you seeing?
SlowPlay is offline
Old 06-22-2011 | 05:17 PM
Stock 28 bravo 1's in my 1997 382 with tired hp's just bumped 70mph on a good day with a light load. Motors are fresh now and the lake is too low to test. hoping to get a few more mph and then tweak the props.
sdodson1 is offline
Old 06-22-2011 | 05:40 PM
t500hps's Avatar
21 and 42 footers
My (former) 2002 had 34P Bravos when I got it but after removing Prochargers and building 540's I ran 32P Bravos. I later went to 15 5/8 28P Maximus with similar results but better cruise speeds.
EDIT: Your boat is a 95 and a straight bottom. I'm willing to bet that drops pitch 2 points.
t500hps is offline
Old 06-22-2011 | 05:51 PM
SlowPlay's Avatar
ive got 4 blade 24p coming. i hope its enough, im reading alot of 26 and 28's under similar setups.
I jujst hope i can get by with these.
SlowPlay is offline
Old 06-22-2011 | 06:04 PM
A friends 06 382 with 496HO's spinning labbed 26's bumping the rev limiters, 5050rpm on a light load at 70.
Back4More is offline
Old 06-22-2011 | 07:20 PM
BONDO10's Avatar
04 with 525's,running 28 Bravo's,with a Bblades touch. I also have a set of 26 Maximus. Great mid range cruise,but just feel like they have to much bite.The 28 Bravos give up a mile or two midrange,but pick up 4 mph on the top end. 75-76 mph. Hope this helps.Jeff
BONDO10 is offline
Old 06-22-2011 | 08:26 PM
Hydromotive 15.5" x 29 - 5 blades, I'm also have shorties...575 SCi's with intercoolers...estimated HP 625-650, best top speed 83 GPS.
kjm5125 is offline
Old 06-23-2011 | 08:00 AM
JB Marshall
My 28" Bravos are 4 blade and I push 72/73 @ 5400 rpms. I have only pushed her there twice since I bought her back in 05.
