New formula owner, water in cabin ?? >
Old 10-01-2011 | 10:20 AM
Prater's Avatar
Mine was coming through the bulkhead between the gas tank and cabin. I ran the water hose in the cockpit and noticed the rear drains were going into the space around the tank. It rotted the bulkhead and was coming through a few spots in the fiberglass. I am in the slow process of rebuilding the rot damage around the bulkhead. I sealed the cabin hatches, still had water, I sealed the windshield and still had water. I pulled the carpet and started spraying the boat with water and found the problem.
Prater is offline
Old 10-02-2011 | 07:13 PM
Any unsealed wood under the floor in the bottom / in the cabin I wonder ? Water coming from under the floor is scaring me for rot !!
oldscoolscarab is offline
Old 10-02-2011 | 09:49 PM
I'm having the same issue with mine and I'm pretty sure that it's coming in from the windshield, mostly when it rains. When I'm driving the boat water seeps out from u der the dash and lands on my feet. I am having a very hard problem keeping the nose up when it's in my driveway because it slopes downward. The water gathers under the step and what I find odd is there is no drain plug.
The first time I had it in my drive and the bow was lower then the stern we got a hard rain and that's when I realized that I was going to have a issue with water in then cabin. I had to use a shop vac to suck it out then kept a fan down there to dry it out. I wonder if there is anything else that could get damaged from it which scares me.
s022mag is offline
Old 03-24-2012 | 08:44 AM
buckknekkid's Avatar
getting anywher with your water issue?
buckknekkid is offline
Old 03-25-2012 | 09:15 PM
Audiofn's Avatar
Charter Member #232
We have had a few guys on these threads say that it also came from under the cockpit floor. So if your boat is dry and you drop the bow low then that is were I would look. Other places that guys have found it from the hatches, windsheild, and rub rail.
Put your best foot forward!
Audiofn is offline
Old 03-26-2012 | 06:27 AM
Anyone try drilling the rear bulkhead?
Old 03-26-2012 | 06:52 AM
Audiofn's Avatar
Charter Member #232
I don't think you would want to do that because then the bilge water could get in there?
Audiofn is offline
