Diamond Plate in 382 >
Old 10-02-2011 | 08:31 PM
RedDog382's Avatar
I had my treadplate anodized before I installed it. Just used the same trim piece to hold it in place.
Attached Thumbnails Diamond Plate in 382-treadplate-001.jpg   Diamond Plate in 382-treadplate-010.jpg   Diamond Plate in 382-treadplate-011.jpg
RedDog382 is offline
Old 10-02-2011 | 08:37 PM
Thanks,
You just gave me another project I have to do.
shinglman is offline
Old 10-02-2011 | 10:23 PM
Expensive Date's Avatar
Originally Posted by kjm5125
What did you use as "edge material" at the perimeter of the plate? Same stuff that was holding down the gray polyvinyl Diamond Plate?
I did not totaly understand what you meant,till I saw Red-Dogs photos.The 382s are different tahn the 292s I just used the screws that the held the rubber mat down.I left the aluminum perimeter on the wood as it was fine.The piece I cut just dropped in the center.
Expensive Date is offline
Old 10-02-2011 | 10:49 PM
PhantomChaos's Avatar
Chris......take a look.....there is a motor missing there. Just trying to help out! How about a "now" picture to see what it looks like after a few years.....
PhantomChaos is offline
Old 10-03-2011 | 11:35 AM
RedDog382's Avatar
Motor was out to check out an oil temp problem, turned out to be just a sticking oil thermostat.
Unfortunately probably a thick layer of dust collecting on the tread plate now, she's still sitting in my building back in Ohio. Waiting until I get the money to construct a storage building at the house here in Vegas before I bring it out west.
Old 10-04-2011 | 09:34 AM
Looks good, what gauge?
kjm5125 is offline
Old 10-04-2011 | 03:01 PM
C_Spray's Avatar
Diamond Member #001
I got rid of the edging by forming the diamond plate around the wood. I used .090" material, and clear powder-coated it once it was cut and formed. I also narrowed the center section/widened the doors to give better access to the strainers. 4 years later, I've seen no signs of corrosion...
Attached Thumbnails Diamond Plate in 382-platform20080308b-large-.jpg   Diamond Plate in 382-platformport20080426b.jpg
C_Spray is offline
Old 10-04-2011 | 04:22 PM
RedDog382's Avatar
Sorry I don't remember and can't find the receit, it was from Tri-state Aluminum on Tracy Road in Oregon, Ohio. 419-666-0100.
Old 10-04-2011 | 04:24 PM
RedDog382's Avatar
Nice Chuck! If only you had some access to a professional fabrication shop ...
Old 12-05-2011 | 01:15 PM
Chuck....I think this is what I'm going to do too. Thanks.
