Formula 382 W/Ilmor 725's
#121
Here is an example of water pickups on a 353 Fastech
With the move from Bravo XR`s to Imco SCX Drives (two inch shorter) there was not enough water pressure coming from the drives water pick up
These new water pick ups work perfect - as the SCX do
#122
Dave
#123
everything is the same as the factory except.....1.5" higher X and I removed the gen pickup and the holding tank macerator discharge from the bottom, The gen feeds from the sea strainer and I have no Y valve, I just pumpout at the fuel dock. I cant imagine the factory would leave anything on the bottom with the ilmor's I think I would break 100 with Herrings. But its fast enough
#124
Formula is using a Teague water pick up mounted to bottom of transom, but I can't see them in the pictures.
#125
MiR - I suspect that your pickups are on the bottom of the hull, which is the latest trend. These are usually cut off pretty close to flush after they are installed.
#129
Saw a Scarrab about 10-12 or so years ago up here called "FAR BEYOND DRIVEN" I like it. Guess you have to be a Pantera fan
#130
