X-Dim on a 382 Fastech >
Old 01-09-2012 | 06:07 PM
RedDog382's Avatar
Originally Posted by kreed
Thanks for the help... azz-end looks nice! You running dry exhaust?
Thanks Kreed! The Stellings boxes just make any boat look sick.
Previous owner had 950 hp blower motors w Stellings headers, therefore the water dumps on the transom. I have CMI elbow tops with water re-entering at the tip of the tails just outside the transom. Still sounds pretty healthy but not obnoxious. GGB mufflers keep the DNR guys from getting too eager to stop/board my vessel.
If you have the hardware off the transom, you might want to seal all the exposed surfaces with epoxy to prevent water intrusion and eventual dryrot. Also had my fiberglass guy do this when I had my boxes off.
Attached Thumbnails X-Dim on a 382 Fastech-strainers-005.jpg   X-Dim on a 382 Fastech-strainers-004.jpg   X-Dim on a 382 Fastech-strainers-007.jpg
RedDog382 is offline
Old 01-09-2012 | 06:18 PM
RedDog382's Avatar
Note in the last photo above that we placed a small notch in the center at the bottom of the cutout to allow water to drain out into the bilge and not collect in this area.
Old 01-09-2012 | 08:15 PM
Red dog, was the wood exposed when you removed the original outdrives? I thought formula sealed all the cut outs?
1MOSES1 is offline
Old 01-09-2012 | 08:42 PM
SS930's Avatar
I can't believe how many boats from so many different manufactures left the factory with the bare wood exposed, really sad! So much for attention to detail...
SS930 is offline
Old 01-09-2012 | 08:58 PM
No thanks to scot I have the answer to my own question.
http://www.offshoreonly.com/forums/f...ech-way-2.html
1MOSES1 is offline
Old 01-10-2012 | 05:50 AM
RedDog382's Avatar
Formula does seal the cutouts. You can still see some of the white gelcoat in the corners of the cutout. No bare wood, but the gelcoat was starting to break down so together with my fiberglass guy (who used to work for the Navy and fixed all the stuff the Seals broke), we decided it was best to sand everything down to bare wood and seal it with epoxy while it was apart to prevent problems with water entry down the road.
Old 01-10-2012 | 09:07 AM
SS930's Avatar
That's good to know. OTOH, as I mentioned I've seen various boats over the years that have had the raw wood exposed... I can't imagine why anyone would let that go out of an OEM like that! Probably just laziness and saving a buck.
SS930 is offline
Old 01-10-2012 | 09:09 AM
SS930's Avatar
Did I owe you an answer to something?
SS930 is offline
Old 01-10-2012 | 09:11 AM
No, but I know your exact intention!!!!
1MOSES1 is offline
Old 01-10-2012 | 09:12 AM
SS930's Avatar
Originally Posted by TxHawk
Kreed, you should send the boxes to Stellings to have them aligned while they are off.
Curious... What exactly are they aligning/aligning to when this is done? What changes over time?
SS930 is offline
