-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   X-Dim on a 382 Fastech (https://www.offshoreonly.com/forums/formula/268492-x-dim-382-fastech.html)
TxHawk 01-10-2012 09:28 AM
Originally Posted by SS930 (Post 3590055)
Curious... What exactly are they aligning/aligning to when this is done? What changes over time?
The carriers have shims to align with the gimbal. They bolt in and seem to move over time. The carrier takes the place of the coupler, so its like aligning the engine. They really are a mess. They are great in that you can move them, but the IMCO with the long shaft into a coupler seems like a better deal. It takes two U joints and a carrier out of the equation.
Think, you have an adapter on the flywheel with drive shaft bolted to that, U-Joints on both ends of a short drive shaft then bolted to a flange that rides in the carrier. From there you have the input shaft of the drive which has more joints.
Honestly seems like a spinning mess waiting to happen but they look cool!
SS930 01-10-2012 09:56 AM
Gotcha, thanks for explaining that!
SS930 01-10-2012 12:14 PM
Originally Posted by 2fast9tech2 (Post 3590053)
No, but I know your exact intention!!!!
I dont think you did based on your comment. ;)
kreed 01-11-2012 07:09 AM
I assume now that Im adding boxes, Im gonna need a longer shift cable?
PremierPOWER 01-11-2012 09:45 AM
No, it is the same shift cable. Make sure you anchor the cable otherwise it could get torn up in the driveline.
Andy
kreed 01-13-2012 08:25 AM
Andy
Will do, thank you...
SS930 01-18-2012 06:40 AM
I don't know why you'd give up that beautiful Tiger, it sure is pretty! :party-smiley-004:
kreed 01-25-2012 11:10 AM
Hahaha, too late! Check the avitar Scot!
