X-Dim on a 382 Fastech >
Old 01-10-2012 | 09:28 AM
Originally Posted by SS930
Curious... What exactly are they aligning/aligning to when this is done? What changes over time?
The carriers have shims to align with the gimbal. They bolt in and seem to move over time. The carrier takes the place of the coupler, so its like aligning the engine. They really are a mess. They are great in that you can move them, but the IMCO with the long shaft into a coupler seems like a better deal. It takes two U joints and a carrier out of the equation.
Think, you have an adapter on the flywheel with drive shaft bolted to that, U-Joints on both ends of a short drive shaft then bolted to a flange that rides in the carrier. From there you have the input shaft of the drive which has more joints.
Honestly seems like a spinning mess waiting to happen but they look cool!
TxHawk is offline
Old 01-10-2012 | 09:56 AM
SS930's Avatar
Gotcha, thanks for explaining that!
SS930 is offline
Old 01-10-2012 | 12:14 PM
SS930's Avatar
Originally Posted by 2fast9tech2
No, but I know your exact intention!!!!
I dont think you did based on your comment.
SS930 is offline
Old 01-11-2012 | 07:09 AM
I assume now that Im adding boxes, Im gonna need a longer shift cable?
kreed is offline
Old 01-11-2012 | 09:45 AM
No, it is the same shift cable. Make sure you anchor the cable otherwise it could get torn up in the driveline.
Andy
PremierPOWER is offline
Old 01-13-2012 | 08:25 AM
Andy
Will do, thank you...
kreed is offline
Old 01-18-2012 | 06:40 AM
SS930's Avatar
I don't know why you'd give up that beautiful Tiger, it sure is pretty!
SS930 is offline
Old 01-25-2012 | 11:10 AM
Hahaha, too late! Check the avitar Scot!
kreed is offline
