Early 90's formuls >
Early 90's formuls
Early 90's formuls
Old 02-22-2012 | 07:04 PM
My 1991 242SS . . . same thing . . . the bulkhead between the engine compartment and fuel tank was not fully glassed and rotted away. I happened to hit the area with a pressure washer and sort of blew it away. I repaired the effected area . . . better than new.
tpenfield is offline
Old 02-22-2012 | 08:47 PM
I do not know how wood in boats is not wet. (note: saying this after working on only one formula, but saw this in several that I looked at first to include scarabs)
The center stringer on my 86 - 272 was made by two pieces of 3/4" ply about 18" tall and 48" long. These were the outside "skins" with a 2x2 at the bottom and a 2x6 at the top (or 2x2 and a 2x4) to form a hollow stringer with the ends open. The water in the bilge was free to flow right down the middle of this, so of course it was rather wet. Now, the stringer was shorter than the span so the wood did not contact the bulk head or the transom and I think this is what saved my transom. The center of the bulk head also seems solid. I have removed all the wood from the center stringer and will be casting it solid. Will be much stronger given that it was 1/2 hollow before.
The front bulk head buts up to the stringers running forward and where they meet they are joined by a 2x2 to help hold it all together while they are glassed in. Water from the unprotected bulk head soaked into the 2x2 and transferred to the stringers since there was no air gap or glass seperating them. Get wet in one spot and it starts spreading. Now, the center bulk head will dry out due to its exposure, but it will take forever to get those stringers to dry out!
The front bulkhead is also gone due to a leaking cabin door and the water took out the stringers going forward about four feet from where they joined together, so it soaks plenty far once one piece gets wet.
Now wet wood is different from rotten wood. Much of the wood in the center stringer was a major pain to get out, had a lot of strength left in it. Only a small part of the engine compartment bulk head was rotten, but it all got wet. The stringers going forward are wet, but the wood will not come out unless you drill it and chip it out. If they use the correct wood, it will survive wet for quite awhile. Also, I believe rot requires oxygen, so wood that is wet and buried under glass may survive longer? Not sure.
My point or question is this. How does anyone NOT have a wet center stringer and if your bulk head got wet, how are the forward stringers not wet as well? May not be rotten, but seems like they all would be wet unless rack stored under cover and never left in the water or exposed to rain! I am just looking at how the wood was laid out in the boat and do not see anyway to prevent it from getting wet over time unless stored in a dry environment.
With my limited exposure to boat interiors, I am curious on what others think of my "analysis of the situation".
befu is offline
Old 03-08-2012 | 04:51 AM
Update . . . I re-checked my boat based on some of the on-going discussion of bulkhead and stringer rot. It looks like deterioration went from the bulkhead to the stringers. So, I'll be taking things apart over the next few weeks. Here are a few pictures showing the cause and the effect.
The Cause . . .
The Effect . . .
There still seems to be lots of supporters of wood structures for boats, and if sealed properly, wood will last a long time. I think the practical issues experienced in production fall short of that longevity goal, and it looks like Formula is not exempt from these issues.
I also think that is why you see the bigger boats going to composite structures, 'cuz who wants to tear apart a 35' boat after 20 years.
Anyway, my situation is not too bad, and I know I can fix it better than new - probably will not use wood in the repairs.
I've seen worse issues on other brands of boat after fewer years. So, I'm still a Formula Fan. I'll know what to look for as I consider upsizing to a 272 or 292 at some point.
Old 03-08-2012 | 10:17 AM
I just bought a 272 sr1. The old hammer test sounds good on all places I can reach. Floor throughout boat and cabin feels solid. Hoping to do more inspections when I need to do something with motors.
Crude Intentions is offline
