Is there another fuel filter besides the fuel/water separator? >
Old 05-10-2012 | 10:49 PM
Default Is there another fuel filter besides the fuel/water separator?
Giving my 88 242 LS with 454 Mag a tune up and want to make sure I don't miss a fuel filter other than the separator. Is the separator the only one or is there another fuel filter somewhere? I've done a lot of research on this board and others and can't find a definitive answer. Also, is the Napa Gold 3225 the corrector fuel water separator? Thanks in advance,
Eric
Cashed Out is offline
Old 05-11-2012 | 10:15 AM
There is sometimes a small in-line screen filter just off the carb. Also, there is often a screen filter on the end of the pickup inside the tank. Other than that, the water separator is the only "real" filter.
ThirdBird is offline
Old 05-11-2012 | 11:26 AM
Remove the fuel line from the inlet of the carb, unless it was removed, should be there if it still has stock carb on it. I had 365hp mags and both had them.
BC
Cold Sweat is offline
Old 05-11-2012 | 01:03 PM
Great, thanks guys.
Old 05-11-2012 | 06:24 PM
Default fixx
Originally Posted by Cashed Out
Great, thanks guys.
the one on the carb should be what they call a rock filter,,all you have to do is clean it with carb spray and blow it off and reuse it..
FIXX is offline
