382 Footwell help >
382 Footwell help
382 Footwell help
Old 05-21-2012 | 04:33 PM
Default 382 Footwell help
Ok I am at a loss all breakers show good, but both my power foot well's are not working. 97 382 fastec. everything else including the seats are working but neither foot well will. Anybody have any pointers? would love some suggestions before I have to rip the carpet off them and pull them out. Going to check power at the switch tonight but I can't see both sides going at once! Thanks in advance! Sean
sdodson1 is offline
Old 05-21-2012 | 05:28 PM
Good question....my passenger side foot rest is not working...
kreed is offline
Old 05-22-2012 | 01:51 PM
There is a connector located inside the side storage area where the wiring from the boat's harness plugs into the seat's wiring harness. Check that connector and make sure it is completely plugged in as any separation or corosion of the connectors may be preventing power transfer between the switch on the seat and the actuator in the foot step well. I just re-furbished a 97 419 and had to re-work some of those connectors to get my seat and steps to work.
38fountainecman is offline
Old 05-22-2012 | 04:28 PM
Thanks! I will check that tonight! I did recently go thru both side compartments to check my gear and that might just be it!
sdodson1 is offline
Old 05-22-2012 | 06:12 PM
Default fixx
easiest to check power when the foot rest is removed,look in the center of the carpet,their is a half circle piece of carpet and under that little piece is a phillips screw,remove upper and lower screw and the whole foot rest comes off the motor assemble..most likely the motors are seized from being in watger,whyle your in theif take a hose and flush out the drains,they plug up over the years and thats what makes the foot well hold water that kills the foot rest motors..
FIXX is offline
Old 05-23-2012 | 08:36 AM
So there is just 2 screws holding them on? I thought I had read on here you had to remove the entire upper and lower piece of carpet to get them out?
sdodson1 is offline
Old 05-23-2012 | 08:28 PM
Default fixx
my bad,sorry its 4 phillips screws..this is how mine looked,dont know if someone cut them of if formula did this ..
FIXX is offline
Old 05-24-2012 | 08:27 AM
Thanks I will feel around and see if I can find them without having to totally remove the carpet. My 97 is a little different carpet layout. it has 2 rectangles with rounded corners and doesn't wrap around the upper like yours. I am going to try that this eve. They worked fine the first time out but I have gad some electrical gremlins since!
sdodson1 is offline
Old 05-29-2012 | 10:45 PM
on my 97 382, you can reach up under the top step (there are tabs to pull) and the carpet will pull back (not glued) to reveal 2 srews holding on the cover to access the motors
Jeff H
Jeff H is offline
Old 05-30-2012 | 10:43 AM
Jeff H
Great thanks Jeff. I brought the boat in to the house to do some work on it and thats one of the first projects. Now if TAG will let me know who made my darn battery charge so I can have it fixed I will be in fine shape!
sdodson1 is offline
