Formula 242 won't engage gear forward or reverse >
Old 09-03-2012 | 04:13 PM
Default Formula 242 won't engage gear forward or reverse
So I'm driving boat bout 40 mph yesterday and it died , after I got it started it would not engage gear forward or reverse , shaft going into motor would not turn and the smell of burnt rubber was coming out of that area , any ideas here people before I tear the thing apart
Matjluk is offline
Old 09-03-2012 | 04:30 PM
Burnt rubber in that area is a sign of a bad coupler usually
Unlimited jd is offline
Old 09-07-2012 | 10:41 PM
When I put a motor in my 223 SS I didnt route the shift cable behind the steering rack like is supposed to be and it chafed on the coupler. I smelled rubber and shut it down and was able to make it home but I imagine if you let it go a little longer you wouldnt be able to get it into gear.
just something easy to check before you yank the motor.
CMG223 is offline
Old 09-08-2012 | 07:17 AM
good thing to check before yanking the motor.
But shouldn't the shaft into the drive always be turning on an alpha or bravo drive? I would think only something with a transmission behind the motor would have an output shaft not turning, like a TRS. Definately points to coupler.
Odd that it would kill the motor. I would have thought that you would just stop moving and the motor would rev with the coupling broke and burning from friction.
Brian
befu is offline
Old 09-08-2012 | 02:17 PM
Shaft not turning while motor running = failed engine coupler. hf...
halffast is offline
Old 09-08-2012 | 02:29 PM
Replaced mine last week...not a fun job. Make sure you align your motor after replacing the coupler.
miller high life is offline
Old 09-08-2012 | 03:13 PM
Better check the drive make sure it didn't lock up and tear the coupler
Old 09-08-2012 | 05:37 PM
Amen!! That happened about 2 years ago to my parent's boat.
Old 09-08-2012 | 07:03 PM
never thought of that! That would really stink to yank the motor, pay for a new coupler and then to just rip it apart also when you went to restart them....
Will have to keep that one in mind.
Brian
befu is offline
