I am officially an Idiot >
Old 09-28-2012 | 03:09 PM
Default I am officially an Idiot
So I installed a new thermostat in my port engine. I run the motor on the hose to check for leaks and I didn't get one of the hose clamps on right, leaking water. Shut down engine, shut off hose, reposition clamp and make sure tight.
Turn engine back on to check for leaks and the operation of new thermostat. Run engine for a few minutes and realize I didn't turn the water back on
Scratch one impeller, new impeller ordered, drink beer with whiskey chaser and call myself dumb azz.
glenncal1 is offline
Old 09-28-2012 | 03:30 PM
It's happened to all of us!
Unlimited jd is offline
Old 09-28-2012 | 05:51 PM
It has??? J/k well it hasnt happen to me, but I have started my boat on fire LOL
88242LS is offline
Old 09-28-2012 | 11:20 PM
Dtile's Avatar
I started motors with drives all the way up...first time in 30 yrs.
Dtile is offline
Old 09-29-2012 | 08:18 AM
I saw the title to the thread, and my first thought was "When did I start that thread?"
I did this the second time out last week - I need a pre-boat check list I think
Brian
befu is offline
Old 09-29-2012 | 10:29 PM
I once put in a new impeller and switched the intake and discharge hoses on the sea pump around by mistake. Drove two hours to go boating and idled out and burned up the impeller. Back to the trailer and back home. I feel your pain.
Revd Up is offline
Old 09-30-2012 | 08:20 PM
Audiofn's Avatar
Charter Member #232
I had some one winterize my boat and they never hooked the hose up to the water pump from the pick up! I ran the motor on the hose (thank god!) and was like WTF is that freaking noise. I was checking my tranny fluid, drive fluid... Finally looked around and saw the hose in the bilge! You may get lucky and find the water pump is OK if it was still wet from when you ran it before.
Put your best foot forward!
Audiofn is offline
Old 10-02-2012 | 07:28 PM
When I trash an impeller, I don't mess around. The thing didn't have one vane still attached to the hub, rebuild underway.
Old 10-02-2012 | 09:16 PM
I did the same thing minus burning it up! Luckily I was watching for water and when it didn't I pupp the hose off the thermostat housing and it wus sucking! Then swappd back... had plenty of grease when I threw it on, so i didn't toast it! :-)
nailit is offline
