Wood in transom of 2001 353 Fastech? >
Old 11-05-2012 | 01:28 PM
Default Wood in transom of 2001 353 Fastech?
When did they stop using wood in the transom?
I think Ill be looking at a 353 quite soon..
skidolof is offline
Old 11-05-2012 | 03:48 PM
PhantomChaos's Avatar
News to me.
PhantomChaos is offline
Old 11-05-2012 | 04:12 PM
They didn't stop . . .
tpenfield is offline
Old 11-05-2012 | 04:45 PM
i think he might be confusing the interior parts that they made from plastic such as hatch trunk back seat ect
smokin' gun is offline
Old 11-05-2012 | 05:51 PM
So what you all saying is that Formula still use wood in the transom??
Monaco20 is offline
Old 11-05-2012 | 06:49 PM
2003 fastech 292 I just took apart has wood in transom
Unlimited jd is offline
Old 11-05-2012 | 07:31 PM
The only wood in the structure of the boat is the transom. The stringer system is a composite grid. All Formulas have a wood transom. Jeff Wurl
jwurl is offline
Old 11-05-2012 | 07:38 PM
haha it's true all fastechs still utilize wood core transoms with composite stringers. formula does gel coat the cut out so when looking it will appear white.
1MOSES1 is offline
Old 11-05-2012 | 07:49 PM
Yep I was under the impression it was composite, until you told me and now that I've taken it apart I found yes wood transom with white gel spread over the bare wood to seal.
Old 11-06-2012 | 01:21 PM
Thanks for sorting this out guys!
With a little bit of luck tomorrow, Ill own a 2001 353 Fastech by the end of the day!
Have been in the market for a Fountain 35EX for quite some time (mostly because I couldnt afford the 353)
But then this object showed up, looking forward to take a look at it!
skidolof is offline
