382 fuel line >
382 fuel line
382 fuel line
Old 04-19-2013 | 05:35 PM
Default 382 fuel line
I have a 1996 382. I am going to add return lines to the tank. does any body now the fuel fill hose size? I am 300 mile away from the boat and need to order the the part.
shimmy820 is offline
Old 04-19-2013 | 10:43 PM
You can run the return line directly to the fuel tank. There are extra fittings in the top of the tank . There is a removable panel to access it under the rear seat. jeff Wurl
jwurl is offline
Old 04-20-2013 | 12:11 AM
Default fixx
+1,,,he stole my words..pull trhe center of the floor and you will see the extra fittings with plugs in them..
FIXX is offline
Old 04-20-2013 | 09:30 AM
Is it under the inspection panel with the sending unit. or do i pull the whole center section of the floor?
Old 04-20-2013 | 10:01 AM
It is the inspection panel for the sending unit. You do not need to remove the floor. Jeff Wurl
jwurl is offline
Old 04-20-2013 | 10:05 AM
thanks thats why i come here first before i rip in to it.. i just got tired of that stupid vst. you now what size fittings that I need ?
