Couple issues on the 312 >
Old 04-21-2013 | 07:56 AM
Default Couple issues on the 312
Gettin the (new to me float) ready for the year a few things discovered, need some help from all of you. Once the key was in, turned and power on, the tab pump on starboard side started running and won't shut off. Could it be a short in the wiring?
Secondly the throttle has the thumb switch that controls the trim, the wiring has pulled out and is not working, once in a while it will come on and work. Is there a cover/boot to go over throttle shafts to keep the exposed wiring from pulling out of the button? Thanks guys!
Rossman40 is offline
Old 04-21-2013 | 09:32 AM
Full Force's Avatar
Sounds like a short, or bad switch for tab sticking... them tabs have seperate pumps like K planes??
Full Force is offline
Old 04-21-2013 | 09:37 AM
Yes. Disconnect from switch completely and was still running
Old 04-21-2013 | 09:38 AM
Full Force's Avatar
Gotta be a short of could also be a solenoid sticking, send me a pic of unit....text it to me..
