Mcleod bolster adjustment malfunction?! >
Old 06-07-2013 | 07:56 AM
Default Mcleod bolster adjustment malfunction?!
Hi!
I having trouble with my stb bolster. The seat adjuster dosent work any more.
Its stuck in the down position, if i push down the motor runs. But if i push up, nothing happens.
I guessing the solenoid, but where is it located? In the bolster or somewhere else?
And what type of solenoid?
skidolof is offline
Old 06-07-2013 | 02:47 PM
You can call formula directly and get the information for the correct solenoid, and if they don't have them they should be able to point you in the right direction. I had trouble with my manual seats once, the seat wouldn't hold firm, so if I sat in it it would drop and then raise back up when I moved out of its way. Turned out the button was stuck.
Might be a bad switch too, you switch out parts with your port and see if that helps.
s022mag is offline
Old 06-07-2013 | 04:22 PM
No solenoids just a switch. Go to Mcleod's site for their # and call them for a replacement.
brian41 is offline
Old 06-08-2013 | 03:14 PM
Ok, thanks. After some exercise the switch began to work again!
skidolof is offline
