98' 353 502 Powered Coil Question >
Old 08-22-2013, 09:40 AM
Default 98' 353 502 Powered Coil Question
My 98' 353 is powered by factory 502's, and I'm interested in getting replacement coils for the ignition system. The installed factory coil has a bracket attached with two screw holes taped, used to hold the coil in place. I'm not having an easy time located this part with the bracket/drilled flange attached. Any suggestions?
BoeingPilot is offline
Old 08-24-2013, 11:35 AM
offthefront's Avatar
MSD make a HEI replacement coil ....I think it comes with a bracket or you can remove the brackets on the old coils.... drill the rivets out and bolt them on the new coils.....m
offthefront is offline
