23p prop on a 242 >
23p prop on a 242
23p prop on a 242
Old 09-27-2013 | 01:17 PM
Default 23p prop on a 242
hi all! im new to this boat and just wondering if anyone is running a 23p prop and how they like it cruise, out of the hole top speeds etc. The boat is an 89 242ls with a 454mag and bravo 1. I am currently running at 21p mirage and seeing 5k rpms and 56/57mph gps, I would like to get the rpm down a little and maybe see some better numbers up top.
KMONEY306 is offline
Old 09-27-2013 | 05:49 PM
chadman99's Avatar
i run a 23 mirage non plus on my 242 . i see about 66 mph (gps) @5200 with 3-4 people and and a half tank of fuel but thats with a 502 with about 475 hp
chadman99 is offline
Old 09-28-2013 | 09:30 AM
thanks. anyone else.....
Old 09-28-2013 | 11:40 AM
Formula311-SR1's Avatar
What 21P mirage are you running? Plus or non Plus?
Formula311-SR1 is offline
Old 09-28-2013 | 06:42 PM
Non plus
Old 09-28-2013 | 10:45 PM
I think you would be right where you need to be with a 21 mirage plus then.
Our 242 ran much better with the added cup of the stock mirage plus props. Carries the bow and rides much better with the added cup.
There is a cheap one to try listed here:
http://forums.boatfreaks.org/showthread.php?t=27688
Old 09-29-2013 | 06:59 AM
masi242's Avatar
On my 242 I run a bravo 1 four blade 22p best I have seen is 56gps, my four blade is labbed a little bit.
masi242 is offline
Old 09-30-2013 | 08:10 AM
what kind of hour blade? im supposed to try out a hydromotive 23p 4 blade this week.
Old 10-12-2013 | 08:13 AM
I am running the Mirage 21plus that came on my boat. Can only get 45 Miles per hour at around 5200 ( 454 /400hp). Salt water. Not sure whats wrong. Previous owner got 60 mph on lake.
shekmark is offline
Old 10-12-2013 | 11:10 AM
Def something wrong there. Sounds like you're getting too much rpm and way too little speed. Are you trimming it out etc. Is that speed GPS or the speedo?
