Motor pull on 242 LS >
Old 11-04-2013 | 01:25 PM
Default Motor pull on 242 LS
pulling the motor out this week. Looking at everything it should come out sideways without removing the seat or hatch... anyone have any experience with this and am i correct saying nothing needs to be removed?
KMONEY306 is offline
Old 11-04-2013 | 02:06 PM
I've pulled the engine in my 242 a few times and I didn't twist the engine to get it out. It is a tight fit but it will come out, removing the crank pulley will give you a bit more room and make the job easier.
endeavour32 is offline
Old 11-04-2013 | 06:34 PM
I did the engine on my 242SS, which needs to have the sunpad removed in order to get the engine out. I would think on an LS you could get it straight out as long as you can raise the sunpad high enough.
http://home.comcast.net/~tpenfield/W...he_Engine.html
tpenfield is offline
Old 11-04-2013 | 08:12 PM
thanks guys!
Old 11-05-2013 | 08:31 AM
Nope- Sunpad MUST come off, I didn't mention that as I figured that was a given.
Old 11-05-2013 | 08:44 AM
If it was a given I wouldn't have asked Lol! Thanks for that reply tho it would suck to get to that point and then have to remove it.
Old 11-12-2013 | 10:31 AM
pulled the motor, transom assembly and platform, platform was dry as a bone. let the fun begin!
Old 11-12-2013 | 10:49 AM
Any big plans with the motor?
Fischan is offline
Old 11-12-2013 | 11:07 AM
Gonna have the heads freshened up, mild cam, emi thunder exhaust probably an msd ignition and maybe new csrb that's about it. Needs valve seals so I figured while its out may as well wake it up a little.
