F-330SS Bulkhead Replacement
#123
Thanks for your good words . . . however, I just realized that I hooked up the waste tank incorrectly . . .
. . . so I'll have to make a quick fix.
It is a good thing that I took lots of pictures during the dis-assembly, as that is how I caught my error on the waste tank.
. . . so I'll have to make a quick fix.It is a good thing that I took lots of pictures during the dis-assembly, as that is how I caught my error on the waste tank.
#124
Hate when that happens, bummer.
When I was putting my dozer back together I started running into the third time was the charm
Took three times to get it together correctly because I forgot something, no pics for me. Hope this is the last redo :}
#125
I corrected the connections to the waste tank . . . here is a picture of the proper connections, just for reference. I had forgotten to run the feeder hose from the shower bilge, so there are 3 connections, not the 2 that I had initially done on re-assembly.
Just a few more odds & ends to do to get everything else back together.
#126
Your shower bilge goes to your waste tank? That's gray water which everything else I've seen can go right over the side. This is the first I have seen, so this means that everything including your sinks all wind up in your holding tank?
#127
Yup, that is how it is plumbed . . . It took me a while to figure it all out, as I originally assumed as you stated.
#129
I am pretty much done, a few odds and ends to address.
Here is a photo of the new bulkhead with all the wiring and hardware installed.
So, it looks pretty much as it did before, but the boat is now sound again. I am finishing off some pre-season maintenance at this point and should be ready to launch in a week or so. I am hoping that the boat has a whole different (better) feel to it with all of the repairs made.
#130
Launch day is Saturday (June 21st). . .
I have a few odds and ends to take care of Fri-Sat AM. Hopefully things will go OK, but there are always a few surprises with this amount of work done to a boat.
