311 Engine compartment >
Old 06-28-2014 | 07:06 AM
Well the dreaded day finally came Memorial Day weekend, I blew one of my TRS drives.. So looks like time for a tear down and go thru every thing.. Has some play in the gimbles so I am going to go ahead and pull engines/trans and go rebuild the gimbles and spruce up the engine compartment....
Any other 311-357 owners out there wanna share pics of their engine compartment? Looking for some cool ideas while I have it apart such as lighting,relocating trim pumps. over all cleaner look...
theadamv1 is offline
Old 07-01-2014 | 05:51 PM
Great question.
Add drain hoses to the oil plugs and the cooler plugs and the block plugs if you can. Talk about speeding up winterization.
I use compressed air to blow through any non-oil drain hose that is not flowing good amounts of water, to help prevent crud from blocking the drains and trapping water in the block/coolers.
Chart is offline
