419 with bravos >
419 with bravos
419 with bravos
Old 10-14-2014 | 12:36 AM
Default 419 with bravos
What drive shower does everyone thing is the best for the bravo one drives? Just bought a 419 with 502 efi motors and wanting to put the showers on the drives. What's the best halo or the top cap showers?
BabyFormula419 is offline
Old 10-14-2014 | 05:47 AM
I would recommend the drive shower that does not require that you drill a hole in your cavitation plate. there are a few out there that mount on the drive where the trim cylinders through bolt to the drive. I drilled holes in my cavitation plate and had to deal with corrosion from time to time. I had a 97 419 fastec and it was an amazing boat. I loved the triples, I have always thought it is a great way to get a lot of hp in a boat without all the high end maintenance of a 700+ hp engine. Good luck.
38fountainecman is offline
Old 10-14-2014 | 06:00 AM
Jimmy, I use the Simrek ones and I've always been really happy with them.
Plowtownmissile is offline
Old 10-14-2014 | 06:02 AM
jeff32's Avatar
Wich one did you buy?
jeff32 is offline
Old 10-14-2014 | 11:02 PM
That's what I had on the Baja, the halo style that goes over the top cap of the drive... Haven't got any yet, going to be getting some over the winter...
