Outboard Powered 330 SS >
Old 12-23-2019 | 06:50 AM
  #61
I know their 4 blades are 15.25 diameter. That is what they are sending with our engines in a 24p. I have no experience with their characteristics but the Revos have absolutely blown away any comparisons on every boat I've put them on. Even down to a flat bottom aluminum boat.
I may be wrong in saying the revolutions would be a better choice than the suzuki 4 blade props. I doubt it, but I have not ran the Suzukis to compare. However, I do know that if you are having cavitation issues the best step in the right direction would be ditching a 3 blade wheels. As long as your engines arent too high that is. I doubt they are or you would be having cavitation on the top end, not while plaining.
Redneckcustoms13 is offline
Old 12-23-2019 | 08:11 AM
  #62
Originally Posted by alindquist
This is really cool, if you are getting 1.6 mpg at 42 mph that is awesome. My 330 with 496's was at 1 mpg no matter what. you just picked up a ton of range... What is the plan for the engine compartment?
I agree, 1.6 mpg is impressive. I'd be curious what the original burn rate was since the 280 was never offered with big blocks.
afratki is offline
Old 12-23-2019 | 10:51 AM
  #63
It happens at any speed, I have tried trimming up and down with minimal result.
fotonews is offline
Old 12-23-2019 | 10:55 AM
  #64
If you are in town please stop by, I need advise to fine tune this experiment.
fotonews is offline
Old 12-23-2019 | 11:05 AM
  #65
Generally speaking if it is cavitating at most all speeds then yes the engines are too high.
Old 12-24-2019 | 11:58 AM
  #66
I agree
hogie roll is offline
Old 12-30-2019 | 08:38 AM
  #67
FYI, filled fuel tank this morning with 80.7 gal. Did 157.1 miles which means 1.95 miles per gallon. I was doing 1.55 with inboards. 21% better fuel economy.
fotonews is offline
Old 01-01-2020 | 06:06 PM
  #68
Did you get to try moving them down?
Old 01-02-2020 | 12:00 AM
  #69
I’m hoping to do it next week
fotonews is offline
Old 01-07-2020 | 07:22 AM
  #70
Took boat to 20 hr service yesterday (had 43 already), told service owner about issue ventilation/cavitation and to lower engines. He insisted the issue must be the wrong props so next week sea trial again, will see...
fotonews is offline
