-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Just got done piping through the silent thunder platform (https://www.offshoreonly.com/forums/formula/327356-just-got-done-piping-through-silent-thunder-platform.html)
Mr Maine 06-15-2015 02:39 PM
I just got done piping through my platform. I think if you search "thru thunder" or similar there are threads where others have done it.
I enlarged my tips from the 3.5x4.5 to 5.5x4.5 inches so they now are nearly square and much larger looking. I then used 4inch stainless pipe and rubber exhaust hose and piped from the tip on the transom to the newer larger square tip on the platform. I used a flange that bolts to the square tip from inside the platform and this is where the transformation from the round 4 inch pipe to the square tip occurs. I cut and welded 45 degree angle elbows to make the offsets.
Externally the only difference is the larger tip, but it is now straight thru exhaust. It is much louder now, and somewhat louder in the boat.
The job was a pain but I wanted to keep the factory platform and have true thru hull exhaust so it was worth it to me.
donzi matt 06-15-2015 02:48 PM
Pictures please!
Mr Maine 06-15-2015 04:06 PM
I have some pics but can't post as I'm not a paying member.
Jonesyfxr 06-15-2015 04:36 PM
I believe if you have a Photobucket account you can post pictures.
donzi matt 06-15-2015 04:47 PM
Or email them to me and I will post them for you. PM me if you want my email address.
86242ls 06-15-2015 05:39 PM
No need to waste your money on a message forum, post to photbucket then embed the picture here
donzi matt 06-15-2015 05:40 PM
4 Attachment(s)
Here are the pictures Jeremy sent me, what a cool project. I miss that boat.
[ATTACH=CONFIG]542158[/ATTACH][ATTACH=CONFIG]542159[/ATTACH][ATTACH=CONFIG]542160[/ATTACH][ATTACH=CONFIG]542161[/ATTACH]
Mr Maine 06-15-2015 06:08 PM
Thanks for posting those DM, next is external steering but I'm going to clean her up and drive her for now.
Jonesyfxr 06-15-2015 06:43 PM
Looks nice!! Where'd you get the rubber exhaust tubing from?
Mr Maine 06-15-2015 08:22 PM
It is just common 4 inch exhaust hose. I got it from Hamilton marine.
