Ayone have a Formula 271 Sr1 with a 496 Ho ?? >
Old 08-05-2015 | 01:18 AM
Default Ayone have a Formula 271 Sr1 with a 496 Ho ??
Looking for info regarding Formula 271 Sr1 with 496 HO
I have innstalled a 496 HO in mine
I have a lot of questions handling, speed, proppeller etc
Please chime in
Monaco20 is offline
Old 08-05-2015 | 07:12 PM
New 496 HO installed, 51 knot first trip ( 58,7 mph) XR Drive and Bravo 1 24 pich kinda flat water 4800 rpm
Goal 60 mph what kind of prop ??
Attached Thumbnails Ayone have a Formula 271 Sr1 with a 496 Ho ??-image.jpg   Ayone have a Formula 271 Sr1 with a 496 Ho ??-image.jpg
Monaco20 is offline
Old 08-06-2015 | 06:25 AM
You could try a 23 Mirage plus, should give more top speed
Mr Maine is offline
Old 08-06-2015 | 07:51 AM
For more top end you would want to go up in pitch.
Splitdecision271 is offline
Old 08-06-2015 | 05:28 PM
Yeah I was thinking of tryin both Mirage 23 + and 25 +
I wonder if a mirage 25 + will spin easer then Bravo1 24 as I have now ?
Thinking about 3 blades contra 4 blades ;-)
Monaco20 is offline
Old 08-06-2015 | 05:34 PM
Hi Splitdesicion
As far as I know the rpm of the 496 HO is from 4800 - 5200 and I am now around 4800 it will be har do go up in pich. If I can spin the 3 blade Mirage 25 pich closer to 5000 then I will gain some. Or if I could spinn a Mirage 23
Closer to rev limit I could maybe gain a litle :-)
Monaco20 is offline
Old 08-06-2015 | 08:05 PM
A 25 mirage plus will be harder to turn and slower. More comparable to a 26 bravo. Try it if you have one but I'm betting on the 23.
Mr Maine is offline
Old 08-07-2015 | 04:53 AM
Gear ratio of the drive?
Rattlesnake Jake is offline
Old 08-07-2015 | 07:24 AM
Originally Posted by Monaco20
Hi Splitdesicion
That's what I thought too but Merc's website says your 496's range is 4600-5000. It was always my understanding that the lower you went in pitch the less top end you got. Although I recently dropped from 28s to 26s. I didn't lose much but boat definitely feels better out of the hole with full fuel and gear and RPM increased just a bit. Still haven't hit the limiter yet so thinking my set up is just right.
I would think it would have a 1.5 on her.
Old 08-08-2015 | 08:29 AM
Hi Guys
Thank you for the replies :-)
RJ : I think all Bravo1 XR are 1.50 ratio
Split: I also saw that on the manual, but everybody I speak with says 4800 - 5100 :-)
I would like to spin around 5000 - 5100 and now with the Bravo1 24 I spin 47 - 4800 I know for a fact that Bravo1 props are
aprox actually 1 pich less then they claim. 24 is the a 23 etc.
So I was thinking that I could reach 5000 - 5100 with a Mirage 23+ which then shoul give me a higer top end + ? ;-)
Anyway the most important thing is that everything works :-) A modern Mercruiser as the 496 HO (200) is new for me, and I like that
Monaco20 is offline
