-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Anyone change Lens on Bomar hatch - mine is cracked (https://www.offshoreonly.com/forums/formula/345086-anyone-change-lens-bomar-hatch-mine-cracked.html)
snowrunner 03-01-2017 07:47 AM
Trying to fix a cracked lens on my 353. Called Bomar, they told me they have replacements for 98 and previous because the handles were ultra-sonically welded.
Anyone have luck replacing the lens and gluing the handles back on? I need to get this fixed ASAP, as the boat is at the painter - the graphic goes across the lens.
Thx.
Eric
F-2 Speedy 03-01-2017 08:09 AM
What shape is it
Redneckcustoms13 03-01-2017 09:19 AM
Pictures would help a little
snowrunner 03-01-2017 09:24 AM
It's Square
snowrunner 03-01-2017 09:28 AM
Will add pics later, need to get the hatches from the painter
ph1971 03-01-2017 07:37 PM
Might try running it over to a glass shop. They may recognize the glazing compound by sight. 3m make all sorts of different goops that those guys use for the shower enclosures and so on.
snowrunner 03-01-2017 07:44 PM
yeah, the sealant isn't the issue for me. Its that the handles are welded to the lens. i now have a company that can supply the lexan cut to form, just need a way to bond it well. Acrylic and the abs handles are two materials that are hard to bond.
Mseuro 03-01-2017 08:46 PM
You might consider using handles that require bolts and or screws like mine do.
snowrunner 03-01-2017 08:49 PM
i wish they made them for my hatches. Bomar said the new style (99+) don't work with 98 and previous.
ren3 03-02-2017 08:54 AM
Your best solution is to replace the hatch if you can not mechanically fasten the old handle onto the new plexiglass. It is going to be difficult to bond to the plexiglass permanently. Epoxy will not work. Cyanoacrylates will not work for long. You might call Plexus Adhesives for some advice.
