-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   22p Bravo I on my 242LS; results, questions (https://www.offshoreonly.com/forums/formula/347752-22p-bravo-i-my-242ls%3B-results-questions.html)
bbender785 06-19-2017 07:56 AM
so my boat came with a 21p Mirage Plus that has overall been a good fit; acceptable holeshot, a top end right at 4700rpm and 53mph. I'd read about people liking the way a 22p Bravo I four-blade performs; a loss of a few mph on top, but improved holeshot and cruising characteristics. I do quite a bit of cruising with the family and wanted a second prop, so to eBay i went.
fast forward to this weekend running the pre-owned 22 B1 for the first time. as anticipated, holeshot was definitely better, and top end definitely reduced a few mph (saw a best of 50.8 on gps). i was under the impression this wheel would help with the porpoise issue i have cruising around the 3k rpm mark, but it definitely didn't.
here is my question: i can't spin it any higher than 4300rpm; does this sound right, or do you think it's had some work done? should my 454/330 be able to spin it closer to 4500-4700, or have all the testimonials i've read come from 454/365 boats? if i had it worked to get the rpm's up, would i gain much top end back?
oconnor marine 06-19-2017 09:48 AM
i had the same boat, it was an 88 with 330 and bravo 1.5 yours and mine left the factory with 23p mirage plus, so with that prop before I modified the motor, i got 4300 ish rpm and 52 mph. on the best day. aprox if memory serves me correct
. the boat would porpose when heavily loaded with passengers and gas and take some time to get on plane. So I got a stainless turning point 19 pitch 4 blade. The boat rocketed up on plane, the stern lift was amazing. I gained about 200 rpms max (4600) and lost about 3 miles per hour, BUT it made the boat awesome, i could tube with the kids, elimnated porposing and no more telling people to get up front for a second or three to plane out quicker. hope this helps. I would at least try a lower pitch, 4 blade. i am surprised the prop you bought didn't improve/eliminate proposing......the turning point eliminated it for me.
ph1971 06-19-2017 09:51 AM
You are a bit over propped.As a general rule you should drop an inch iof pitch going from three to four blade. I'm guessing a 20p is just right. If it was me I would look for a 450 hp motor to put in front of that new prop. Ha ha.
bbender785 06-19-2017 10:23 AM
i was under the impression it came with the 21p mirage plus. i also have a 23p mirage plus from a previous boat that i tried for the sake of data that was too much prop, couldn't get that one past 4200 rpm.
definitely over propped now, that's why i was curious what i'd get by having the 22p worked to closer to 21 or even 20; 22p is the smallest B1 made.
trust me, i'd love to slide a 502 in that bilge! hopefully someday. had one in my last boat that was smaller and lighter... miss that motor.
Redneckcustoms13 06-19-2017 10:32 AM
You need to find a revolution 19 and try it. I'm running around 425hp a d yesterday was my first run on my new to me bravo 22. It made me happy still a light porpoise but I can trim out of it. I've been running my revolution for a while and love it just wasn't enough wheel for my cruising I do.
bbender785 06-19-2017 10:40 AM
Originally Posted by Redneckcustoms13 (Post 4562874)
I'm running around 425hp a d yesterday was my first run on my new to me bravo 22..
what rpm were you turning with that power? could you trim all the way up without it ventilating?
Redneckcustoms13 06-19-2017 10:42 AM
My cruise rpm was 3700-3800 speed 38-39. Im dealing with a bad trim sender so I can't tell you where the trim gauge was but I could definitely over trim it.
masi242 06-19-2017 07:29 PM
I did have my 22pitch labbed and got back to 4600 max rpm, i have a 454 330hp alpha and it does fine. You will need to have it worked.
Jpm540 06-20-2017 06:55 PM
Brandon, the 242 with 330hp 454 came from the factory with a 21p mirage. My 242, before I repowered, had the same engine, bravo one, 21p mirage and I recall similar rpm and speed as what you seeing.
Jpm540 06-20-2017 06:57 PM
Any by the way, I'm always interested in more power so let me know if you want my 502mpi!!
