Formula 311 Bilge question ? >
Old 11-22-2017 | 05:51 PM
Default Formula 311 Bilge question ?
Everyone that has a Formula knows about the issue of water getting trapped to under the step. Every picture that I have seen of that area has a drain the runs from that area to the main bilge except, on some 88 and 89 model 311,s. Sometimes I get water there and it coming from the bilge because I dropped a drive oil bottle once and I can see the residue make it to under the step. But wheni crawled down and looked for a drain tube there is none to be had. I there is no passage to allow water to got forward of the bilge pump float. What gives?
Fastninja434 is offline
Old 11-30-2017 | 01:44 PM
TomZ's Avatar
I'd be really concerned if you had engine room water coming up into the cabin. On my '88 the areas are completely separated.
TomZ is offline
Old 11-30-2017 | 08:21 PM
My 1990 has a drain that runs from the cabin to the engine compartment. Another source of water is windshield leak around the screws and it doesn't stain the headliner.
switchbackman is offline
