Led bulbs for courtesy lights >
Old 05-03-2018 | 07:29 PM
I found bulbs for the cabin, courtesy, gauges on Amazon - probably spent less than $50 for every bulb in the boat.
snowrunner is online now
Old 07-09-2018 | 11:48 AM
What color did you go with. I am going blue in the engine compartment as well as courtesy lights! Gauges I am curious what you went with?
Mike
formula 382 is offline
Old 07-09-2018 | 11:59 AM
Hello Mike;
I used the KINGSO lights shown above and they are white only. But I'm certain you can find other colors. Good Luck.
Vince
VPelliccia is offline
Old 07-22-2019 | 09:22 AM
Where is the light switch for the engine bay lights on a 1988 F311?
Thanks!
F14A water jet is offline
Old 07-22-2019 | 10:25 AM
My 242 comes on with the courtesy lights
DBleil89 is offline
Old 07-22-2019 | 10:47 AM
Found it on the dash panel, cockpit and engine...same switch.
Old 11-18-2022 | 07:29 PM
New issue...I did find that the two DSRAM 5008 swithable spotlightes did NOT work with new LEDs. Turns out the polarity was reversed and since the 5008 bulbs can only go in one way, I had to switch the wires going into the light socket. Works 100% now!
