Remove 353 V-Berth Panel and Couch Cushions >
Old 05-24-2018 | 07:07 AM
bn
Default Remove 353 V-Berth Panel and Couch Cushions
Does anyone know how to remove the v-berth panel in a 2002 353? My anchor locker drain is clogged and I would like to get access to the drain hose to check what's clogging it.
Also, does anyone know how to remove the couch cushions in the cabin? Thinking about adding A/C some day and would like to know how to remove them so the plumbing and electrical can be run under the cushion.
bn is offline
Old 05-24-2018 | 08:22 AM
You don't want to access the hose from inside if you have water sitting in the anchor locker. You'll get an awful mess inside your boat.
Best to use a flexible probe, like a wire snake, from the outside drain fitting into your locker. May need to add water to the locker to help flush out the crud. Likely mud/vegetation came up with your anchor and is clogging the line. Formula made that drain line too small in my opinion.
Chart is offline
Old 06-02-2018 | 09:42 AM
Veteran: Navy
I want to know also how to remove the starboard side Lounge seat on my 292. Want to add AC
AmiableDave is offline
Old 06-02-2018 | 05:40 PM
There was never anything but a dry line and a spider or two in that anchor locker.
Rippem is offline
Old 06-02-2018 | 08:16 PM
I man pretty sure you can access that drain line by just removing the mirror section in the front. Jeff wurl
jwurl is offline
Old 06-03-2018 | 01:02 AM
No way an AC unit will fit under there
Griff is offline
Old 06-03-2018 | 09:37 AM
If you dive into the area between the upright back cushion and the seat cushion there probably are a couple Phillips screws buried
fossil fuel is offline
Old 06-03-2018 | 08:47 PM
Veteran: Navy
Under where? I installed the shorter seat on the Stbd side and I'm going to have a cabinet made to house the A/C
Old 06-04-2018 | 01:57 AM
I guess that will work. You implied under the seat
Griff is offline
Old 06-05-2018 | 08:54 AM
Veteran: Navy
I didn't imply anything. And where above did I say that I want the A/C unit under the seat?
