Remove 353 V-Berth Panel and Couch Cushions
It's a little on the ghetto side. But this last weekend I sat a 5k btu window unit at the base of my door to the berth and ran it off a Honda 2000. Worked great just had to set it up and when I got done I set it in the floor in front of the step.
Redneckcustoms13,I've had a Pompanette Thru-Hatch Portable Air Conditioner for 2 years now. I store it like you do. And I don't have to tell you what has to be done when you want to go somewhere. That's why I'm customizing the interior of mine. I'll add a couple of 120 outlets, and a microwave also.
You asked about how to remove a lounge seat and wanted to add AC. You didn't mention anything about having a cabinet built.I'll make sure not to respond to any other questions you might have about anything
I was able to get the anchor locker drain cleared by adding water, blowing out/up the drain from the bottom with an air compressor, shop vacing up the dirt and water and repeating several times. There wasn't much, but drain hose must be really small.
