Removing the Silent Thunder - New Platform Coming >
Old 06-10-2018 | 02:19 PM
Tom, Info on that flush kit please.
Redneckcustoms13 is offline
Old 06-10-2018 | 10:35 PM
TomZ's Avatar
Flush kit... I do not like having it on the side of the boat. It was there when I got her, and I understand putting it there versus on top of the transom since the Silent Thunder blocked access.
With that said....
I love how this thing is set up. The flush attachment connects to a set of valves behind the seat in the bulge. I can open up the valves to supply water to one or both engines to handle flushing.
The whole thing is a Perko hose connection to a
sst of ball valves that control water flow. Outputs go to a tee into the seawater pump. I hook up the hose, apply water pressure, and then open a valve per engine. Simple.
TomZ is offline
Old 06-11-2018 | 07:50 AM
Now that your ST platform is gone you could move your flush connections directly above the drives like in the video I posted, I believe there should already be a hole there from a Through Bolt. You could always just put a water dump fitting where your flush connection is now. Tips Look Good!
TylerBurich is offline
Old 06-11-2018 | 08:33 AM
TomZ's Avatar
Hadn’t thought of that!
TomZ is offline
Old 06-11-2018 | 04:01 PM
Very nice. Those tips have a period correct look. I’m ready to see the new step.
ph1971 is offline
