What’s it worth? 1990 242ss >
What?s it worth? 1990 242ss
Old 09-10-2018 | 12:40 PM
  #61
If you have a v8 22 you need to be at 11-12 base for a total of 33-34 all in.
Redneckcustoms13 is offline
Old 09-10-2018 | 12:52 PM
  #62
I think that 330 hp calls for 32* total and max 4,200 - 4,800 rpm. With a 21 prop I would think even being tired it should pull 4,200 rpm.
What gps speed did you get? Keep at it you will get there.
GLENAMY 242SS is offline
  #63
Would 1 or 2 degrees make a difference of 1000 rpms?
Skirby12 is offline
Old 09-10-2018 | 01:04 PM
  #64
I didn’t really get much of a chance to open it up. It was pretty rough. Hit 30 mph on gps but only for a few seconds. Conditions were less than ideal. Lol. Also. How much is an acceptable amount of water in the bilge? Seemed to be a bit maybe 5 gallons when I pulled the plug. There was a bit of splash over on the trip so that could have accounted for some of it. I haven’t checked the bellows which I will this week. I would think it should stay pretty dry for the most part. If bellows check out is there anything else I should be looking at? When it’s running the cooling system isn’t leaking so that’s all good
Skirby12 is offline
Old 09-10-2018 | 01:14 PM
  #65
I have plenty of weekends where I pull the plug and nothing at all comes out. Some it's just a quart or so from people and the kids on and off a dozen times a day. You shouldn't be getting much if any. Bellows obviously, then any hoses. Also are you putting teflon tape on your drain plug? I found mine needed it to fully seal without having to tighten it to the point I felt it was over tightened.
Old 09-10-2018 | 01:24 PM
  #66
I did wonder about Teflon tape. I haven’t put any on but will try that next time to see if that makes a difference. I would like to see no water in the bilge.
Skirby12 is offline
Old 09-10-2018 | 02:13 PM
  #67
Also check your speedometer hose. They are prone to deteriorate over the years.
Old 09-10-2018 | 03:14 PM
  #68
Ok. I will definitely check that too. Seeing as the speedo doesn’t work. Maybe that’s it. Stupid question. Where is that located on the transom end?
Skirby12 is offline
Old 09-10-2018 | 08:04 PM
  #69
5 gallons is a problem that you need to address. I had a corroded transom assembly that leaked in a way that was hard to diagnose until I had replaced every other possibility. Poke around the sides of the bellows hub with a screw driver to detect soft spots. Saltwater boats of this age are proned to TA failures. At the very least an auto pump switch is a good bet. Don’t sink my sister ship! LOL.
ph1971 is offline
Old 09-17-2018 | 05:36 PM
  #70
Another update. Went out yesterday and the seas were calm so hammered the throttle and only got 3400rpms and maxed out about 38mph. Cruises nice at 3000rpm and around 30 mph. I’m thinking it’s the timing but still have to find an advance timing light. Ran good. No coughing or sputtering. I did find out that the fuel gauge is not accurate. Had to get the tow of shame back to the harbor. Ran out of gas about 3 miles away from the dock and gauge still read 1/4 tank. At least now I know all old gas is out and gauge is off. Lol. Probably the sender. All in all great day on the water!!!!!
Skirby12 is offline
