292 props
Old 10-28-2002 | 12:02 PM
BUSTNOUT
Default 292 props
I'm running a 2002 292, started out with the factory 28's was having real tough time on the hole shot ,switched to 26's better out of the hole and mid range lost it on the top end. I now hear the factory is shiping the 2003's with labed I think 28's .Does anybody know what kind of performance, with this setup?
Old 11-15-2002 | 12:11 AM
HOUSTONPROP's Avatar
what a deal /does not help help out the prop guys but everything must change , sounds like great advice on the drives.
HOUSTONPROP is offline
Old 11-17-2002 | 11:15 AM
Charter Member #415
Be careful about moving that spacer, it can cause some weird handling if too much throttle is applied before you trim out.May be ok for most of us but don't loan out your boat to someone who isn't familar with it. Formula put that spacer that way for a reason. Not saying don't move it, just saying use caution.This also appliies to 271's . Magicfloat
Magicfloat is offline
fastmcars
05-07-2008 07:49 PM
Phazar454Mag
12-20-2007 05:52 PM
docbones
04-12-2005 04:12 PM
BUSTNOUT
05-26-2003 07:58 PM
BUSTNOUT
07-22-2002 05:59 PM
