What is the function of this hole/orifice? >
Old 07-09-2019 | 08:50 PM
Default What is the function of this hole/orifice?
See below picture of my 1988 F311 Sr-1
F14A water jet is offline
Old 07-09-2019 | 08:58 PM
you have an anchor locker up there?? drain...
phragle is offline
Old 07-09-2019 | 09:39 PM
aquaforce's Avatar
That can be configured differently depending on the vessel but the anchor locker drain is mostly what that is for. Some Formulas may have the hole but no anchor locker.
aquaforce is offline
Old 07-09-2019 | 10:22 PM
This title had very disappointing results.
Baja Rooster is offline
Old 07-10-2019 | 06:58 AM
I'd fill that sucker with 5200 and wipe it smooth.
https://www.offshoreonly.com/forums/formula/32746-vent-hole-bow-2.html
Redneckcustoms13 is offline
Old 07-10-2019 | 07:33 AM
Sydwayz's Avatar
Forum Regulator
If a boat has pull up cleats and pull up bow light, both that have drain cups under them..
...the drains can be tied together, down to that through hull drain.
Sydwayz is offline
Old 07-10-2019 | 08:17 AM
In the very front there is a triangle removable panel, an anchor locker too small for an anchor. That is a drain for that "line Locker"
GLENAMY 242SS is offline
Old 07-10-2019 | 09:11 AM
Old 07-10-2019 | 09:15 AM
Vent hole in bow??
I'm up there (in the front) doing the docking lights...so I will investigate how my boat is configured and probably fill the hole in.
Old 07-10-2019 | 09:28 AM
You said your doing the docking lights? Did your boat not have them and you added them. I’m curious if this is the case. Because mine doesn’t have them but I’ve wanted to add them because I like the look of them.
Smoke eater is offline
