ISO plug/play, self-contained, GPS speedo >
Old 08-12-2019 | 06:46 AM
Originally Posted by Keith
The Livorsi GPS speedo had $2 coin battery soldered into the external hockey-puck type antenna. They wanted $75 (+shipping?) to install a new battery every couple years. Instead, I took a piece of wire and went from my GPS data output, to the gauge data input. Depending on your marine VHF radio model, you can also use the same GPS data feed to send location data to your radio as well.
Very cool...how did you attached the wire (solder, clip, or some sort of plug)?
F14A water jet is offline
Old 08-12-2019 | 07:26 AM
Keith's Avatar
CBPBA's Walmart Greeter
The connection will be exposed to all sorts of extreme temps and weather conditions. It really depends on what you're most comfortable with and how much work you want to do. You don't want water or moisture getting into the splice. The data wires from both devices were very thin so you could use a little dab of di-electric grease on each exposed wire to prevent corrosion before crimping. Use a piece of heat shrink tubing around the connection.
There are really nice weather resistant connectors available like weather pack, molex and others. The advantage to a weather resistant connector is you can take unplug later without having to cut wires.
K2
CHESAPEAKE BAY POWER BOAT ASSOCIATION
'http://www.cbpba.com'
"Experience is something you don't have until just after you need it."
Keith is offline
Old 08-13-2019 | 08:13 AM
TomZ's Avatar
Originally Posted by F14A water jet
Is there a page/menu on your Elite 5 that give a GPS speed readout on the screen?
Tom, yes it has a screen that provides GPS speed along with course direction and waypoint guidance.
TomZ is online now
Old 08-13-2019 | 08:16 AM
TomZ's Avatar
The newer speedometers have an external antenna. My antenna was powered by a 12V source, but didn’t seem to work well. The connection from the chart plotter fixed that.
TomZ is online now
Old 08-13-2019 | 09:13 AM
Thanks I'll look for it.
Old 08-13-2019 | 09:15 AM
Cool!
Did you se the phone message?
Old 08-25-2019 | 11:06 AM
Turns out my speedometer face is 4" in diameter and overall 4.5"...what size do I need? The 85mm was too small :-(
Old 08-25-2019 | 05:26 PM
Originally Posted by shunter2005
Faria Chesapeake model SGP010 (80 mph model), in white or black .
How does this mount in the 3 13/16 mounting hole in the mounting plate on the dash (1988 F311)? The description says "Gauge size: 4" (3 3/8)" but I already tried an 85-87 mm gauge (which my math said would be right at 3 3/8") and it was too small for the opening.
Additionally, did it come with an antenna/speed sensor?
Thanks!
Old 08-25-2019 | 05:36 PM
Originally Posted by ph1971
Don’t have a link but I believe the auto meter part number for the gauge I have is 200646-33.
That part # description says 5"...see above post (about the size opening I have), does this fit without modifications?
Thanks!
Old 08-27-2019 | 11:49 AM
Please forgive me...I have been focused on the trim plate and not on the actual hole in the dash. As you can see in the attached picture, the 3 3/8" (85mm) gauge fits the hole (but not the trim plate. Therefore, for very little money I can have a GPS speedometer...until I decide that I want to pay 5x more for a bigger one, or switch out the tachs (or all the gauges).
Thanks for putting up with me!
Tom
