Formula 242ss new to me
Good looking boat. If your vinyl is in good shape pull the staples off and use old wood for template. I did this with my engine hatch and it worked out great. I ended up using the more expensive ply at big box store and coated it with resin then stapled old vinyl on new wood . Looks like an eagle trailer no? No surprise an old bird needing a little love,hopefully she doesn’t nickel and dime you into regret
Good idea on the upholstery wood, i have done that on my other boat. All the wood on the back seat is pretty rough.
Thanks I always liked the lines. The trailer looks identical to a trail rite, so that.s what I think it is. I replaced the wheel cylinders today, trailer has brakes now. Also finished the raw water pump.
b_fuse. Looks like MohavValley on another forum is a friend of yours. If so I am the person he called/will be calling about. If you can help me out on this I would be in your debt.
If you have any questions on the 242 SS let me know I currently own that model as does a good friend of mine. We have both completely gutted and re-done every aspect of our boats.
Again thank you if you can help me out and best of luck with your new boat.
Also it looks like you have a Bravo 1 prop on it now, if you can borrow a 23" Quad 4 to try I bet you will like the handling and ride MUCH better, also performance.
BTW i was trolling through some posts saw your cleaned up bilge pictures. Looks like you have some o2 sensors? or am i seeing things? Please explain or point me to thread to read more. Thanks
Yes, DLG-1: Dual Lambda (Air/Fuel Ratio) Gauge.
Here is a link to their website.
https://innovatemotorsports.com/products/dlg1.php
Be sure you use 90* extenders, sold through amazon, without these you will be eating sensors at $75 a pop.
I found these)2 sensors very handy in tuning the carb to get low 12's across the entire throttle range. You will be surprised how you need to fiddle with the carb but it can be done and is actually fun.
Once set up a just glance tells you how the engines are running. Call me if you have any questions.
Gary
Gary
